HTML pages¶
Starting with SeaTable 6.2, a Universal App can contain a new page type: the HTML page. You upload a packaged HTML/JavaScript/CSS bundle, and SeaTable renders it as a full page inside the app.
A static bundle on its own can only display fixed content. To turn an HTML page into a real application — a custom form, a dashboard, a calculator — it needs to read from and write to the base. That data exchange runs through the seatable-html-page-sdk.
This section is written for developers. It covers how to set up a project, how to develop and package a page, and the full SDK reference.
Architecture¶
An HTML page is rendered in a sandboxed context inside the Universal App. It never talks to the base directly. Instead, the SDK provides a messaging bridge to the app, which performs the actual data operations.
flowchart LR
A[HTML page] -->|seatable-html-page-sdk| B[Universal App]
B -->|API| C[(Base)]
C --> B
B --> A The SDK offers:
- Data APIs — list, add, update and delete rows; manage links; upload files and images.
- User APIs — read the signed-in user and resolve collaborators.
- Action APIs — send notifications and emails, and run configured Python scripts.
- Event propagation — bidirectional events (mouse, keyboard, drag-and-drop) between the page and the app.
Prerequisites¶
- SeaTable 6.2 or later.
- A Universal App with an HTML page added to it.
The developer setup additionally needs Node.js and npm, and an API token generated in the base for local development. The low-code approach needs neither.
Two ways to build¶
The same kind of page can be built two ways. Pick the one that matches how you like to work — both produce the same uploadable ZIP and use the same SDK.
Low-code quickstart
Design the page in any visual (WYSIWYG) HTML editor, connect it to your base with ready-made copy-paste snippets, and upload. No Node.js, no npm, no dev server.
Best for forms, dashboards and small tools.
Developer setup
Clone the official template and use a full toolchain: modular files, a live-reload dev server, npm scripts and a real build.
Best for larger or more complex pages.
Where to start¶
- Low-code quickstart — build a page with a visual editor and copy-paste snippets, no toolchain.
- Developer setup — set up the project, develop locally, build and upload a page. We follow the official simple form template end to end.
- SDK Reference — installation, initialization, and the full API for rows, links, users, actions, files and images.
Example project
The seatable-html-page-template-simple-form repository contains a complete, buildable form page. It is the running example used throughout the developer setup.
